Teltonika FM1100
Re: Teltonika FM1100
Well , I am able to get gps data via SMS. My problem is how to get GPRS connexion to make the device send data to the server.
Teltonika FM1100
Hi Guys,
just for you to know:
1.) there is an firmware for fm11 which supports gprs commands. Ask your Teltonika guy for that firmware.
2.) FM5300 needs to be used with "custom commands". Just use all commands you find in manual. You dont need to write username/password into the command as they are not necessary in gprs commands.
3.) reply of units are shown as Drivermessage in wialon.
enjoy
Wolf
Teltonika FM1100
Да, мне тоже интересно, как слать команды на телтонику из виалона. Если будет тема по-русски, расскажите, ребята)
вы тут немного подварите, а я дома проволокой намертво примотаю
+79634551777
Teltonika FM1100
hi guys,
we want to SET the "flash-password" of FM11 via SMS and dont know if this is possible?
We already set the username and password to all of our devices but that can be reset by just flashing it. There is an additional password which you need to set if you want to connect it to the configuration software, but i dont know if we can set it just by SMS?
Help would be appreciated!
Thanks
Wolf
Teltonika FM1100
Hello Wolf.
We have no such information. But if we get it we will inform you.
Teltonika FM1100
Configuring Teltonika FM1100, FM4100, FM4200, FM5300 devices via TCP/IP is now available in Wialon.
The process of configuring via TCP includes the following stages:
1) the server (Wialon) sends a binary SMS to the device.
2) the device connects to the server (Wialon) to receive configuration.
3) the server (Wialon) sends configuration to the device.
4) the device breaks the connection.
User must create SMS command Upload configuration (upload_cfg) in Wialon and upload a configuration file while creating or sending the command.
Configuration file must have a certain format described in the Instruction on configuring via TCP the link to which is placed on FM1100 page on www.gurtam.com:
http://gurtam.com/en/gps_tracking/gps_h … ?id=216940
The Instruction:
http://extapi.mos-glonass.com/hw/cfg/teltoni … tcp_en.pdf
Teltonika FM1100
Registration of parameters for LBS Detector (getting position on the basis of GSM parameters) has been added for Teltonika FM1100, FM1200, FM5300
Teltonika FM1100
I have a problem in configuring 1 wire temperature sensor and can somebody help me to know how to add temp sensor, what parameter to choose and how to set the calculation table wizard. The temperature graph to be set should be in the range of 40 degree celsius to -40 degree celsius.
Regards
Abraham
Teltonika FM1100
https://www.youtube.com/watch?v=En4m1IF3RaQ
Teltonika FM1100
Hi,
it is ""param72''  for the FM1100
Calibration table settings:
X  <>  Y
-1000  <> -100
1000 <> 100
It means value divided by 10
Goodluck
Teltonika FM1100
Thank you very much friends.
The system is working fine now.
Teltonika FM1100
I am new in using Teltonika fm1100.i want to monitor fuel and have done tank calibration by getting the changes in voltage due to to changes in fuel levels.i dont plan to use a fuel sensor.In the fm configurator,how can i choose the parameter that wil have me see the fuel in the tank.i have done the calculation tables.kindly assist
James
Teltonika FM1100
james,
use analog input of fm11.
wolf
p.s. connecting additional hw to tank voltage display may result in wrong display of display !
Teltonika FM1100
Hi James,
The parameter is : adc
We also have ""special"" hardware to avoid also the problems with the analog fuel meter, with this you can also detect Fuel Theft etc .
http://www.tracesolutions.eu/fuel-senso … apter.html
regards
Teltonika FM1100
Hello guys,
I have a client in Colombia with issues with the Panic Button (SOS)  on his Teltonika FM1100 devices:
The frequency of messages is every three minutes. When he presses the panic button nothing happens and no new message comes in, but a panic message will come inside the normal message every three minutes.
Me point is, regardless of the Panic Button being pressed or not, the device ALWAYS reports every three minutes. Could you help with the correct configuration in order for the device to send a new message every time the panic button is pressed?
I know the Teltonika FM1100 is very popular, so I was wondering if someone could tell me what would be the best configuration to get everything working nicely on Wialon.
Thanks for the help.
Teltonika FM1100
Hi,
I have a FM5300 on which I try to send gprs commands. I saw in the manual some example commands and was able to reconstruct:
- the first 8 bytes are message length;
- some unknown (but maybe constant) bytes
- then the message as a byte array
- then some extra unknown bytes.
Could anyone detail what the unknown bytes represent and what's the format of the gprs command on 5300 supposed to be?
setdigout 1000 10 0 0 0
$00$00$00$00$00$00$00$21$0C$01$05$00$00$00$19$73$65$74$64$69$67$6f$75$74$20$31$30$30$30$20$31$30$20$30$20$30$20$30$0d$0a$01$00$00$e5$ca
#SET OUT=1,0,0,0
$00$00$00$00$00$00$00$1a$0C$01$05$00$00$00$12$23$53$45$54$20$4f$55$54$3d$31$2c$30$2c$30$2c$30$0d$0a$01$00$00$fd$34
#SET OUT=2,1,0,0
$00$00$00$00$00$00$00$1a$0C$01$05$00$00$00$12$23$53$45$54$20$4f$55$54$3d$32$2c$31$2c$30$2c$30$0d$0a$01$00$00$3e$05
#SET OUT=1,1,0,0 15,30,0,0
$00$00$00$00$00$00$00$24$0C$01$05$00$00$00$1c$23$53$45$54$20$4f$55$54$3d$31$2c$31$2c$30$2c$30$20$31$35$2c$33$30$2c$30$2c$30$0d$0a$01$00$00$83$c6
wwbusch aka Buwo пишет:
Hi Guys,
enjoy
Wolf
Teltonika FM1100
Ricardo Sandor пишет:
Hello guys,
Ricardo,
why not asking me ;-)
you need to set priority in IO setting on Input(x) (where you connect the sos button) to high and set it to send on each change a message.
(basicaly the same setting for the input as you need to set it for ignition to get always ignition on/off )
If you have still problem give your customer my skype and we do a remote session.
Wolf.
Teltonika FM1100
aspacardin пишет:
Hi,
#SET OUT=1,0,0,0
#SET OUT=2,1,0,0
Hi Guys,
enjoy
Wolf
Aspacardin,
what are you trying? Debugging TCP/IP messages or using commands with Wialon?
for first ask Teltonika, for second: Just use commands as i described it, that works fine for FM11 and FM53!
No need to use any kind of "byte/hex" messages
Wolf.
Teltonika FM1100
Thanks for your reply! I need to integrate it with a separate service, so I need to find the commands and it's very hard to get an answer from Teltonika. It's very important for my work and it's frustrating that I'm only missing a few bytes. If you happen to have the protocol, please send it to aspacardin4@gmail.com, it'll help me a lot!
aspacardin пишет:
Hi,
#SET OUT=1,0,0,0
#SET OUT=2,1,0,0
Hi Guys,
enjoy
Wolf
Aspacardin,
Wolf.
Teltonika FM1100
Hi,
sorry, we signed (as all Teltonika Partners) an NDA.
So no way to get the protocol description!.
And come on, you are here in the Forum of Gurtam = manufactor of Wialon. Why they should help you implementing hardware into a competitor software? I would not do that! Never!
Wolf.
Teltonika FM1100
wwbusch aka Buwo
Hello Wolf,
Like always thanks for the help. I'll be contacting you shortly.
Ricardo.
Teltonika FM1100
Hi Everyone,
I'm Xavier, a french newbee working with Wialon since few months.
Well, we need to connect FM1202 and FM 1100 (2 differents needed) with a Block and Unblock engine command from Wialon to the device.
At this time, we have good results with the block engine, as well with the 1100 and the 1202, but we can't Unblock devices when sending the Unblock command.
I'm not sure that is a typical device's issue, but a wrong prg of the commend sent by ourselves;
If anyone of you may help us, it should be greatly appreciated.
Thank You,
Greetings from the south of France
Teltonika FM1100
Hi ""Greetings from the south of France""
Send me a PM and I will send the details ( drawing etc )
regards
Baltika
Teltonika FM1100
I want to configure FM 1100 for a in lab project. When I connect it with my laptop for configuration, i get the error message for using some kind of configurator which I could not find so far.  Can someone guide me please? I have attached the screenshot of the error message.
  • Teltonika FM1100
Teltonika FM1100
Hi,
Read the txt carefully on the picture !! You only need a new configurator. Contact your supplier of the Teltonika units
regards
Baltika
