Mobile applications and smartphone access (iOS / android)
Тема: Mobile applications and smartphone access (iOS / android)
I want to access Wialon through smartphone.
As far I know… “Wialon Mobile is for slow smartphones. If you use e.g. iPhone 3GS you can load PC version.”
I tried with Nokia touchscreen smartphone with 360x640 resolution. With built-in browser of Symbian S60, the Wialon login screen appears; but browser close when login in progress.
Then I tried with Opera Mini 5.1. With Opera I successfully login to Wialon; but most buttons, menus & other controls are not usable. I failed to switch to any other tabs like 'Jobs', 'Units' etc. Also all info in the 'Monitoring' tab is fixed, ie, not updating with time.
I like to know how can I access the Wialon tracking site effectively in the Nokia smartphone.
Can anyone help?
Re: Mobile applications and smartphone access (iOS / android)
Maruf, new, enchancent web-application for mobile devices like iPhone is in development currently. It should be avaible in 1-2 monthes as far as I know the schedule.
shal пишет:
Do you mean that...
[1] Gurtam is developing a new web-app (in addition to existing 'Mobile Wialon') for smartphones which will be released soon?
[2] At present it is not possible to access current Wialon front-end from smartphones effectively?
Maruf пишет:
yep
it is not designed for that, see supported browsers list. But I saw that iPhone for example shows main web-application perfectly. So it more depends on the smartphone browser and officially not supported by us.
shal
If we want to create special application for iOS ourselves what you could recommend to us?
Where is information on Russian or English about protolol?  I mean not Wialon IPS.
Александр Сорокин, АГРОштурман.РФ
Wialon Agro - система мониторинга с/х техники и полей.
1. Extendend  Mobile version for smartphones is already avaible in Wialon Hostoing product.
2. For iOS I can only recommend Wialon IPS.
Is there any updates with an iOS version?
Dwayne78, you mean application that is able to view other vehicles (try http://m.mos-glonass.com with trial registration)? Or application that send itself position to Wialon?
(16/05/2011 10:37:51 отредактировано Maruf)
shal, how to try m.mos-glonass.com? can we use username/password of our Wialon Hosting account?
Maruf, you can use own DNS and own login/password only if you have "Wialon Mobile" package. If you don't have it, register on trial.
In the Wialon Mobile V2 interface, the sensor values are not displayed. It only displays some parameter values which have no meaning to the user. In the mobile v1, at least some what readable values are displayed, although a number of digital sensors custom digital sensors) do not clearly indicate the sensor values.
I request the developers to look into this and add properly formatted sensor values in the v2 interface.
In our country, penetration of mobile phones is far greater than penetration of laptops or computers. A robust mobile interface like the v2 will surely garner a lot of business.
Also, it will be awesome if the mobile v2 can become OS independent. Before the last update on 1 st August, 2011 - the v2 used to work in nokia, blackberry and other normal phones. But post the update it works only on android and iphone.
roadmatics пишет:
The mobile version will get much more functionality in the beginning of 2012 due to update of main web application version to the same technology which is now used in mobile.
roadmatics пишет:
Its a matter of compatibility, may be we need to issue mobile version adopted to each type of gadget. But it is almost impossible to make web application that works same way in all types of phones(embedded browsers).
I have my own device which I understand can be incorporated into you system providing I subscribe to the Wialon hosting package starting at 120 per month.
Is there a minimum sign up period?
My device can also send back its location in the form of GSM cells if GPS not available - can your system deal with that?
Have you checked the list of supported devices?
http://gurtam.com/en/gps_tracking/gps_hardware.html?id=
After signing up you should just pay for the future periods of using the system.
Developer
This is new device that is not on the supported list. Given that some work will be needed by your tech team to support my device I thought I may have to sign up for a minimum period
peterc пишет:
Ok, are you the manufacturer? Provide us more information about that device plz.
Developer
shal пишет:
roadmatics пишет:
roadmatics пишет:
It´s urgent the issue of compatibility. I use Nokia and Samsung, so the new version is compatible. But most of my customers use blackberry and can´t enter.
It´s also necessary to add the following functions:
- See the same sensors that in the web version.
- Send commands to the units.
shal пишет:
roadmatics пишет:
roadmatics пишет:
Now I am too waiting for this more functionality ,any date?
Version 1 has more option than option 2 ,and Safari in Iphone 4 doesnt open mobile version 2 :You should solve this ASAP.
Br
You can try http://mobile.testing.mos-glonass.com it is upcoming Wialon Hosting upgrade, testing branch.
shal пишет:
login,pass
Ask support@gurtam.com access to testing branch. Also look at restricted section on forum for more info.
(08/03/2012 09:55:14 отредактировано aahero)
shal пишет:
Yes this mobile version is muuuch better,version 1 is working fine but V2 currently is crashing in every browser in android tablet ,slow and bugish.I tried Opera mini ,Delphin,standard android browser
Safari in Iphone 4 saying INVALID but safari in Ipad is showing V2 OK.
Still no date on update?
Latest version (not final version) of mobile v2 is available here: http://mobile.testing.mos-glonass.com/ (15.03.2012)
Requirements for mobile operating system and mobile browser:
  Smartphones: Android 1.6+, iOS;
  Desktop: Safari 5, Chrome 10+
Denis Strakh, Gurtam
(08/07/2012 06:08:20 отредактировано gio_dorigoni)
I have problem with the mobile vertion (m.mos-glonass.com) Some times works well and other not? I don't know if it is me but I don't think so, because I change computer and the same... doesn't work!  Then I tested the mobile vertion of gps-trace and that works great... but the paid vertion some days works and other not???
It let me enter the username and password ant then it open the main window but don't let me work or select any option other than logout sad
Anybody else with this problem?
Here is the attachment of the screenshot of my problem....
Now. it is working well again....
yes its just some bugs that they fix
I have subscribed for the Wialon SDK. Where can I download the
wialon_activex_php.zip
I need to access the wialon server using php hosted on a seperate server using PHP. Has anyone been able to do this.
Nishad Hussain Kaippally
Implementation Specialist, Middle East, Gurtam
"Computer science is no more about computers than astronomy is about telescopes."
kaippally
stop spamming the same question in several topics, you have been given new link to php-files  here
WDC Administrator
Is there any planning to give additional functionality to the existing mobile access for Wialon?
Currently we are using a web browser to access the application on Samsung tablets and it works OK for the most part but we cannot move the map with a swipe.
The mobile access is OK for visibility but it would be great if we had some additional functionality particularily for map viewing.
Regards
John
Phoenix Solusi
Mobile Visible Secure
Specialists in data acquisition and analysis for mobile and fixed assets. Integration in to content management systems is a specialty we have.
Hi John,
there is some partners already developing fine Android and IOS apps for watching Wialon via the SDK.
So if your account is enabled for SDK you will soon be able to use nice native Apps.
(ASK is developing one, Kalaschnikov is developing one and also some others)
Wolf.
Thanksfor the update Wolf.
At the moment we are not using the SDK. They will not be releasing the mobile application that they are working on through Google Play?
Regards
John
Phoenix Solusi
Hi JohnG,
as i understood it will be released in google play store.
But nevertheless you need to activate SDK function on your domain (if you are using wialon hosting, SDK for Wialon Pro will be avaiable in next release).
By the way, map moving is working fine under android in mobile website. So what exactly are you missing?
Wolf.
I am accessing the mobile site in Pro using the 8024 port on a Galaxy TAB 10.1 and Galaxy SII using Firefox and it does not scroll on a swipe on either of them. I have to use the arrows that are on top of the map to move it around.
On the Galaxy SII the map and menus shrink to a very small size every time I do anything with it so I am continually trying to resize it.
There is no vehicle list search capability so you have to scroll through the list and at the moment that is 117 units and growing.
The POI's and GeoFences fo not appear so we do not have any references for positioning of the vehicles as we are operating regionaly and Google or OSM have very poor maps in the areas we operate in.
Regards
John
Phoenix Solusi
Hi John,
Mobile site is a very basic site, but why dont you use the default website? it works fine on Android and if you have that big screen its perfect.
On Samsung S2 its of couse a bit too smal but do you realy use geozones etc. always on mobile phone? I dont know any "native" app for gps tracking systems which shows you POI and Geozones etc.
But for Wialon Hosting there will be realy soon some different Apps avaiable.
I think after adding SDK in Pro Version maybe the developer will also add support for Pro Version (also SDK is different as i understood)
Wolf.
Hi Wolf
There is some functionality that cannot be used is the TAB is used for accessing the native application, as finger tap and a moouse click are not always interpreted the same way. We have looked at a product that does have the ability to show thousands of locations but it does not track. It just shows the device being monitored in relation to the custom location.
Most of our users are using mobile devices for monitoring rather than PC's or note books. Plus we need an offline capability direct to a device as we do not always have gprs connectivity. Basically an application that is running on the device that can receive sms messages from the tracking unit and can then alert the user and position the tracking unit on a map that has been cached.
Regards
John
Phoenix Solusi
Hi John
i dont think that there is something ready out of the box what you are looking for.
but why not developing it?
If you use wialon kit it costs you basicaly nothing to store data online at wialon and than just use simple functions on your tab to develop exactly what you need.
and developers in asia should costs not that much if you make a good technical task.
Wolf.
Hi Wolf,
I am trying to get more information on Wialon Kit as i only found out about it a few days ago.
One option was to develop something here .... as you are correct the prices here for development are good.
Regards
John
Phoenix Solusi
Hi
I would to know if exist an app to track or send the signal through a smartphone?, if exist could you recomment me some of them?
Cause recently we will have a Race and we wanna give the service free for a good publicity of our services. I appreciate for the answers.
Regards.
Jorge
soportenanti
service for what?
Андрей Чудин
Глобальные мониторинговые системы, Саратов
https://glomos.ru; https://wialoncrm.com; http://m25.su
chudin пишет:
service for what?
Service to track the people through their smartphone just for a couple of hours
soportenanti пишет:
chudin пишет:
service for what?
there are such services!
Андрей Чудин
chudin пишет:
soportenanti пишет:
chudin пишет:
service for what?
Yes, but we want to use the wialon app and see how there going through Gurtam Mobile Service, in that way we shows how it works to the people, maybe there will be interested in car tracking service, it's more like an publicity strategy.
why not using a software based gps tracker on that phones?
Available for all major smartphone os´s
Wolf.
soportenanti пишет:
Hi
Regards.
Jorge
soportenanti
go here http://gurtam.com/en/gps_tracking/gps_h … /soft.html most of them are free and you cna connect to Orange and then ist completely free
Thank you very much aressun and wwbusch
Dears,
Can anyone help me, how can I use the open street map with android mobile App?
The issue is that we have our own mobile APP and we are showing the last location on the map of each vehicle, we were using Google Maps but we are going to be suspended from using the Google maps due to Google policy.
So we need free map SDK to use it instead on Google and Open Street was one of the options but there is no clear way how can we call its SDK.
Anyone have an experience and can help?
Thanks in advance.
Try to use osmdroid or something from here.
Mobile Development
Hello,
Does anyone know if the Wialon Mobile Application is released in Itunes yet?
Regards
Glenn
Hello Glenn!
Please find here https://itunes.apple.com/app/id960699792
Thank you Chdi.
Regards Glenn
even update is there.
but missing my german translation i sended to you!
Wolf.
The point is that translations for Android and iOS versions are made separately.
You may request language file for iOS at development@gurtam.com
Katerina Alexandrova
Product Manager (Mobile)
