Logistics Release Notes
Тема: Logistics Release Notes
This topic will be dedicated to the updates of our app Wialon Logistics!
Here are the most important links:
The web app
Google Play app
Documentation
Disscussion on the Forum
Tatsiana Shmihelskaya
Business Analyst, Gurtam
Re: Logistics Release Notes
New version 1.11 of Logistics is available.
What's new:
- You can now view files (signature/image) attached to orders. To do that, pick the order and click the "clip" icon.
- We’ve redesigned the orders creation dialog: the text elements and fields on the the left now take less space, so you can work more comfortably with the map on the right.
- Easily create a copy of your order by clicking a "copy" button in the Planning mode.
- In the chat, you’ll now hear a sound notification when there’s a new incoming message. You can click "sound" button to switch the sound off/turn it back on anytime right there in the chat window.
- In the Planning and Routes modes, you can now change the column order for a more convenient display of your data.
- In the Routes mode, search for a specific order in the list: in the left menu find the magnifying glass icon and start typing there. You can search by any of the text fields: “name”, “client”, “phone”, “address”, etc.
- In the settings (“Routes” tab) there’s now an option to manually set coefficients for average speed inside and outside a city. Use them to minimize the differences between the estimated and actual time of arrival.
Denis Strakh, Gurtam
New version 1.12 of Logistics is available.
What's new:
- The function of dublicate the order is improved: when copying, files that have been attached to the order are now transferred.
- API: implemented a request to unload the already formed routes from the Logistics. Description of the request and format in the document.
New version 1.13 of Logistics is available.
What's new:
- Address control in the order dialog: reduce the font size and increase the width of the list with address information so that long addresses can be seen immediately.
- Added displaying the last 5 notifications for the dispatcher when you start Logistics. Clicking on the bell shows the list.
- Bugfix.
Hello, everybody.
August for Logistics - was a very fruitful month - we had two releases: 2.0 and 2.1.
Below is a short list of new features
2.0
- currently active routes are now adjustable - you can add an order into them from the list of "unplanned"
- such actions generate new types of PUSH notifications to the drivers, that are on the go
- Operations in a bulk for orders (you can now edit and delete several of them at once)
- we added few more pop-ups
- loading plan for the route (a vice-a-versa version of an ordinary route)
- visual markout of planned and actual track became better
- if a user has inactive flag "can change his settings" in Hosting - settings in Logistics become unavailable also
2.1
- 4 bugfixes
- shortened address list in the pop-up during the search
- import dialigue usability improved
- step 2 of planning has filters on selected types of units (you are picking orders and the system proposes you to pick necessary units of that type), step 3 has a "reshuffle" button - if optimisation results are not suitable for you, just re-shuffle them again.
Next release is planned to be by the end of the September or early October. We wish to give you several new functions and improved routing so keep an eye on this topic. Just "subscribe" in the lower right corner of this page.
Dear all!
We’ve just released the next Logistics update.
Now, when creating an order, you can enter the coordinates in the “Address” field. This functionality will be useful if delivery is carried out at gas stations or at places where there is no address (roadside, bus stop).
Also, when importing orders, coordinates can be entered in the “Address” field. This functionality will be useful if the address base consists of coordinates and addresses. Accordingly, now it is possible to import orders with both the address and coordinates.
Coordinates must be used in the format 53.905887, 27.456933.
  • Logistics Release Notes
v3.6.1 Logistics
Dear all!
A new column "Confirmation/Rejection time" has been added to the reports. This column records the registered confirmation time and the rejection time of the order.
We’ve just released  the Logistics Mobile update.
1.8.592 - Android
1.6.11 - iOS (will be available next week)
1. Now the application on the Android and iOS platforms will work more stable when the connection is lost and restored, while working with the operator’s and driver’s orders, the operator’s status will prevail;
2. Also improved the work of the built-in tracker.
v3.7.0 Logistics
This update improves the work of the "Warehouses" tab in the application settings.
v3.8.0 Logistics
A new option "Show route" has been added to reports. By clicking on this option, a modal window opens, which shows the planned route of the object.
In this window, you can also see the actual route of the object, when you activate the option "Show/hide actual route"
Also, when you click on the order icon in the route, you can see information about the selected order. The route information window provides information about the selected route.
With the help of the new option, it is convenient to compare the planned and actual routes, see all deviations and analyze the information from reports in more detail.
v3.9.0 Logistics
Dear all!
We have just released the next Logistics update
The ability to create custom fields has been added to the order creation/editing dialog.
Custom fields can contain any additional information.
To create a custom field, first you need to enter a value in the “Field name”, then click on the “Add” button.
You can add, delete, and edit custom field values at the planning stage, in active and planned routes.
Also added custom fields can be displayed in the table of orders at the planning stage. To do this, you need to activate "custom fields" in the table visibility settings.
By displaying custom fields in the order table, you can use all the information you need to make the planning process even more efficient.
Anton Voitenko,
Wialon Product Manager, Gurtam
v3.10.0 Logistics
Hello!
Column group “Custom fields” has been added to unit reports.
New columns display custom fields, where the name of the column is the name of the custom field, and the values in the column is the values of the corresponding custom field.
If the group “Custom fields” is activated in the visibility settings, then when the report is executed, all custom fields for the selected period will be displayed.
Thanks to the new functionality, you can save all the necessary information, as well as bring the analysis of the delivery process to a new level, because the data will always be at hand!
Anton Voitenko,
v3.11.0 Logistics
Good day!
Today we have released the new features update.
We have added the ability to specify custom fields by default.
Add custom fields which should be displayed in the New order dialog box and in the table of orders in the new tab “Custom fields” in the settings:
Click on the “Autoсomplete” button to automatically add the custom fields created earlier in the resource:
You can customize the visibility, as well as change the order of the columns, the names of which are specified in the "Custom fields" tab, in the settings in the table of orders:
With the new functionality, users will be able to work with custom fields faster and more conveniently:
We will be glad to know your opinion about the released functionality, which you can send to voan@gurtam.com!
Anton Voitenko,
v3.12.0 Logistics
- The "Custom fields" tab in the settings has been improved;
- The ability to import orders with custom fields has been added.
1) "Custom fields" tab.
Now you can change the order of fields in the list.  To change the order, drag the field to the needed position.
Now custom fields in the order creation/editing dialog and in the import table will be displayed in the same sequence as in the settings.
2) Import of orders with custom fields.
Now the custom fields, which created in the settings, can be added to the template and directly to the import table.
The custom column added during import and its values will be displayed in the order editing dialog, where the column name is the name of the custom field.
With the help of new functionalities, you can more comfortably and quickly create orders with the information you need.
We are looking forward to your feedback, which you can send by e-mail: voan@gurtam.com!
v1.9 Logistics Mobile
Good day!
We've released the next Logistics Mobile update.
New design and arrangement of elements in the information window of orders.
Added:
- estimated time and estimated mileage between route points;
- delivery interval;
- icons which indicate comments and attachments;
- color indication of late orders;
Anton Voitenko,
v3.12.2 Logistics
Good day!
The ability to show custom fields in Logistics Mobile has been added.
To display a custom field in the mobile version, activate the switch "Show in the mobile application" in the corresponding field in the settings on the "Custom fields" tab.
If you create a route with orders that have custom fields with an activated switch, then the corresponding fields and their values will be displayed in the mobile application in a separate block.
With the help of this functionality, you can display the information necessary for the delivery process directly to drivers.
The user of Logistics Mobile will be able to see only the field that is activated in the settings, so you can choose what information can be displayed and what not.
We will be glad to hear your opinion about the released functionality, which you can send to voan@gurtam.com!
Also, you can always tell us about the functionality that you would like to see in Logistics.
Together we will make our application even better!
Anton Voitenko,
v3.13.0 Logistics
Good day!
We have added the ability to execute report by custom fields for the following types: Driver, Unit group, and Driver group.
If the “Custom fields” group is activated in the visibility settings, then when the report is executed, the custom fields added on the “Custom fields” tab in the settings, as well as their values for the selected period, will be displayed.
Thanks to the new functionality, you can use even more efficient all the necessary information.
The block with custom fields in the order creation/editing dialog has been improved.
Now, custom fields can be created only in the settings, which in turn will provide intuitive control of all the functionality.
Anton Voitenko,
v4.0.0 Logistics
Good day!
We have updated Material-UI library and improved application interface.
Сolor scheme, all interface components, and animations have been improved.
The interface adapts to page resize.
You can comfortably plan routes in windowed mode or even on your tablet.
Now with a new, modern interface, interacting with Logistics will become even more enjoyable!
We look forward to your feedback, which you can send to voan@gurtam.com!
Anton Voitenko,
v4.1.0 Logistics
Hello!
We've released the next Logistics update.
1. Now, if the driver didn't visit the order, the data in some columns* will not be displayed. Thus, the order data will be calculated most correctly.
* - Deviation, Actual mileage, Actual time to point, Fuel consumed, Temperature.
2. Removed column "Actual fulfillment time".
3. Improved statistics logic. Only the order that was actually visited by the driver is considered as visited.
4. Added new columns to the report and statistics.
Now the user will be able to compare the main planned delivery parameters with the actual ones.
For example, comparing the planned time spent on the order with the actual time in the new Estimated/Actual Service Time columns can improve the quality and efficiency of delivery.
5. Added new map layer - OpenStreetMap
Anton Voitenko,
v4.1.1 Logistics
Hello!
1. Added new columns to the "Routes" tab (columns are also available for export and print)
  • Delivery interval
  • Estimated service time
  • Estimated time to point
  • Weight
  • Volume
  • Cost
  • Custom fields
2. New documentation
We have completely revised our documentation. The documentation has become clearer and more user-friendly.
https://help.mos-glonass.com/help/logistics/en/user-guide
3. New phrases in the settings
We have changed most of the phrases in the settings. Now the name and description of the functionality have become even clearer!
Anton Voitenko,
v4.2.0 Logistics
Hello!
1. Added route cost calculation.
A new block is located on the "Planning" tab in which you can specify cost values for the main delivery parameters:
cost per km(mile) of travel, cost per hour of travel, for visiting one order, for using the vehicle.
By specifying the cost for at least 1 parameter, the optimization algorithm will calculate the cost of each route, which will be displayed at the 3rd planning step and on the "Routes" tab both in a new column and in an additional block.
Thanks to this functionality, the user will be able to estimate delivery costs.
2. Custom address format.
We have added the ability to change the order of address information for the source of Gurtam maps.
The address format will be applied from the settings in the Hosting.
Anton Voitenko,
v4.3.0 Logistics
Hello!
We have improved the optimization algorithm.
Algorithm solutions have become 30% more optimal in most planning cases. The new algorithm is already available at http://logistics.mos-glonass.com/!
Planning modes
Now you can customize the algorithm solutions.
We have compiled 3 settings profiles and added them to the application interface.
The user can choose one of the following planning modes:
  • Cost-effective. Select this mode if reducing costs is more important for you than adhering to delivery intervals. The vehicles will be loaded to the full capacity and the total mileage will be reduced.
  • Balanced. Select this mode if reducing costs and adhering to delivery intervals are equally important for you.
  • Fast. Select this mode if delivering goods quickly and on time is more important for you than reducing costs. The maximum number of units will be used for this purpose.
To try out new solutions, just change the mode in the new block in the settings on the "Planning" tab.
Take into account the location of units
If the "Take into account the location of units" option is enabled, the algorithm will plan routes based on the location of both orders and units. As a result, the optimal units will be used and the optimal sequence of orders will be determined in accordance with the selected route planning requirements.
If the unit is following the route, then the location of the last point is taken into account.
The location of units can affect the sequence of points in the routes, the number of units and the main parameters of the routes (duration, mileage)
Strict delivery interval
If the option is enabled, it is planned to deliver the order adhering to the delivery interval. If it is not possible, the order is excluded from the route.
Service within delivery interval
If the option is enabled, the algorithm seeks to include the service time in the delivery interval.
Anton Voitenko,
v4.4.0 Logistics
In the new application version, we are glad to present you with an improved design of the navigation bar and tables.
The filter and the search have been moved from the navigation bar to the toolbar above the tables on the Planning, Templates, Routes, Reports, and Chat pages. The search is now also available at the third stage of planning and in reports.
At the first and second stages of planning, you can reset the filter parameters to the default ones.
Besides, we have made improvements to the routes created from templates: now their cost is also calculated if its calculation parameters are specified on the Planning tab of the settings.
In case of any questions, write to voan@gurtam.com.
