Sensor update behavior Sensolator
Тема: Sensor update behavior Sensolator
HI
I have trouble with displaying values in sensolator.
I send values from all sensors every 30s and in between I send short messages with only gps values. The Wialon app has no problem translating this but sensolator only shows the sensor values every 30s and when the sort messages comes sensolator displays UNKNOWN.
Is there any way to configure sensolator to only update for a specific range of sensor values?
Or could i re translate the messages in any way?
I´d rater not change the message structure from my units.
Re: Sensor update behavior Sensolator
As usual i´ve come across a solution directly after i posted my question.
In Wialon under the specific sensors properties there is a check box that is called last message only.
Unchecking it makes wialon treat the last valid sensor value as the current.
Hi
Try to disable 'Last message only' in sensor properties https://docs.mos-glonass.com/en/hosting/cms/ … sors/props
