How to set Speed Limit in Graph
Тема: How to set Speed Limit in Graph
Hello Everyone
Good Morning
I have a question can i set speed limit detector in any units settings or in templates?
For example- i want to show speed in graph only if vehicle is moving with speed of 20km/h because i'm facing coordinate jumping in teltonika fmb125.
when ignition is off but vehicle is showing moving condition.so that i want to show only speed in graph greater than 20km/h .
Re: How to set Speed Limit in Graph
Hello,
All speed is usually shown in Wialon charts.
But it is possible to solve your issue, just follow the instruction below:
1. Create a custom sensor based on parameter "speed"
2. Set 20 as lower bound in calculation table.
3. Add chart to the report template
4. Add line "Custom sensors"
As a result you'll see value of the sensor that cuts off all the speed below 20.
@ Oleg Zharkovsky
You can set a speed filter in WIALON to only display speed data above a certain threshold, such as 20 km/h. To do this, go to the device settings (e.g., FMB 125), and configure the speed limit in the device or template settings. Then, apply a filter in the graph setup to show speed data only when the vehicle is moving above 20 km/h. This will help prevent showing erroneous data, like when the ignition is off but the vehicle appears to be moving. Test the configuration to ensure that only relevant speed data is displayed.
