Тема: How to run an application made for Wialon Hosting
Hello I had a question to ask perhaps help me to answer this question. Because when you run an application we developed for hosting wialon achievement not run directly from a browser that does not access the correct way. But if the same application is run from http://sdk.mos-glonass.com/playground/ if access is obtained. Clearly we are using the script in the HEAD:
<script type = 'text / javascript' src = 'http: //code.jquery.com/jquery-latest.min.js'> </ script>
<script type = 'text / javascript' src = 'https: //hst-api.mos-glonass.com/wsdk/script/wialon.js'> </ script>
And we do not even use it to access the data. running our application from the browser like this:
file:///C:/Users/User/Desktop/Hab2/index.html
Not running it from the WampServer or XAmp as applications run without testing in Wialon Playground?
