Тема: Вопросы по срипту логина.
При создани скрипта по примеру с возникает ошибка.
Код скрипта что я ввожу:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<title>Wialon Playground - Login</title>
<script type="text/javascript" src="https://code.jquery.com/jquery-latest.min.js"></script>
<script type="text/javascript" src="https://hst-api.mos-glonass.com/wsdk/script/wialon.js"></script>
</head>
<body>
<style>
#log {
border: 1px solid #c6c6c6;
</style>
Token: <input type="text" id="token"/>
<input type="button" value="login" id="login_btn" />
<input type="button" value="logout" id="logout_btn" />
<input type="button" value="get user" id="user_btn" />
<div id="log"></div>
<script type="text/javascript">
// Print message to log
function msg(text) { $("#log").prepend(text + "<br/>"); }
// Login to server using entered username and password
function login() {
var sess = wialon.core.Session.getInstance(); // get instance of current Session
var user = sess.getCurrUser(); // get current User
if( user ) { // if user exists - you are already logged, print username to log
msg("You are logged as '" + user.getName()+"', click logout button first");
return;
// if not logged
var token = $("#token").val(); // get token from input
if (!token) { // if token is empty - print message to log
msg("Enter token");
return;
msg("Trying to login with token '"+ token +"'");
sess.initSession("https://hst-api.mos-glonass.com"); // initialize Wialon session
sess.loginToken(token, "", // trying login
function (code) { // login callback
if (code) msg(wialon.core.Errors.getErrorText(code)); // login failed, print error
else msg("Logged successfully"); // login succeed
// Logout
function logout() {
var user = wialon.core.Session.getInstance().getCurrUser(); // get current user
if (!user){ msg("You are not logged, click 'login' button"); return; }
wialon.core.Session.getInstance().logout( // if user exist - logout
function (code) { // logout callback
if (code) msg(wialon.core.Errors.getErrorText(code)); // logout failed, print error
else msg("Logout successfully"); // logout suceed
// Get current user and prints its name to log
function getUser() {
// print message
if (!user) msg("You are not logged, click 'login' button"); // user not exists
else msg("You are logged as '" + user.getName() + "'"); // print current user name
// execute when DOM ready
$(document).ready(function(){
// For more info about how to generate token check
// http://sdk.mos-glonass.com/playground/demo/app_auth_token
$("#token").val("5dce19710a5e26ab8b7b8986cb3c49e58C291791B7F0A7AEB8AFBFCEED7DC03BC48FF5F8");
// bind actions to buttons click
$("#login_btn").click( login );
$("#logout_btn").click( logout );
$("#user_btn").click( getUser );
</script>
</body>
</html>
Вот что выдает файл Host.html к которому мы обращаемся:
<html>
<body>
<script>
(function(){
var isChunkedTransmissionEnabled = false,
chunkedPrefix = 'posthtml:';
var CHUNK_SIZE;
var chunksQueue = [],
chunksIntervalId = 0;
function postMessageStr(id, win, str, origin) {
if (!isChunkedTransmissionEnabled) {
win.postMessage(str, origin);
return;
var offset = 0,
length = str.length;
var parts = [];
// Split `str` by CHUNK_SIZE blocks
while (offset < length) {
parts.push(str.slice(offset, offset + CHUNK_SIZE));
offset += CHUNK_SIZE;
var chunksCount = parts.length;
parts.forEach(function(part, i) {
// Chunk format:
// `chunkedPrefix` `id` : `chunkIndex` : `chunksCount` : `data`
var chunkStr = [chunkedPrefix, id, ':', i, ':', chunksCount, ':', part].join('');
chunksQueue.push({
win: win,
str: chunkStr,
origin: origin
// Start chunks processing
if (!chunksIntervalId) {
chunksIntervalId = setInterval(processChunksQueue, 0);
function processChunksQueue() {
if (!chunksQueue.length) {
clearInterval(chunksIntervalId);
return;
var chunk = chunksQueue.shift();
chunk.win.postMessage(chunk.str, chunk.origin);
* Listen all "postMessage" events
function listener(event) {
if (!event)
return;
var data = null;
try {
data = JSON.parse(event.data);
} catch(e) {
try {
// Insecure
data = eval("(" + event.data + ")");
} catch (e) {
return;
if (!data || data.source != window.location.href)
return;
// ping request
if (!data.id) {
if (data.chunkedPrefix) {
chunkedPrefix = data.chunkedPrefix;
if (data.enableChunkedResult) {
isChunkedTransmissionEnabled = true;
CHUNK_SIZE = Math.floor(16777215 - (chunkedPrefix.length * 2) - 64 - 512); // 16mb (32 in UTF16) - (approximate header size) - random
var responseJson = "{\"id\": 0, \"source\":\"" + data.source + "\", \"error\": 0";
if (isChunkedTransmissionEnabled) responseJson += ", \"chunkedResult\": true";
responseJson += "}";
event.source.postMessage(responseJson, event.origin);
return;
// construct request
var req;
// creating XMLHttpRequest object for Internet Explorer differs with creating object for other browsers. That's why this operation duplicates for compatibility
if (window.XMLHttpRequest)
req = new XMLHttpRequest(); // normal browser
else if (window.ActiveXObject) // IE
try {
req = new ActiveXObject('Msxml2.XMLHTTP'); // different IE versions
} catch (e) { // create
try { // object different
req = new ActiveXObject('Microsoft.XMLHTTP');
} catch (e) {}
if (!req) {
postMessageStr(data.id, event.source, "{\"id\": " + data.id + ", \"source\":\"" + data.source + "\", \"error\": 1}", event.origin);
return;
//sending request with POST method and with compulsary pointing to handler file (true - asynchronous mode)
req.open("POST", data.url, true);
req.callEventOrigin = event.origin;
req.callEventSource = event.source;
req.callId = data.id;
req.callUrl = data.url;
req.source = data.source;
req.onreadystatechange = function() {
// status OK
if (this.readyState == 4) {
if (this.status != 200 || this.getResponseHeader("Content-Type") != "application/json") {
postMessageStr(this.callId, this.callEventSource, "{\"id\":" + this.callId + ", \"source\":\"" + this.source + "\", \"error\": 1}", this.callEventOrigin);
return;
// getting function response in string
postMessageStr(this.callId, this.callEventSource, "{\"id\":" + this.callId + ", \"error\": 0, \"source\":\"" + this.source + "\", \"text\": " + this.responseText + "}", this.callEventOrigin);
// when using XMLHttpRequest object with POST method it is necessary to send additional header
req.setRequestHeader("Content-Type", "application/x-www-form-urlencoded");
// sending necessary parameters (several parameters separating with ampersand)
try {
req.send(data.params);
} catch(e) {
postMessageStr(data.id, event.source, "{\"id\":" + data.id + ", \"source\":\"" + data.source + "\", \"error\": 1}", event.origin);
return;
// bind event
if (window.addEventListener)
window.addEventListener("message", listener, false);
else
window.attachEvent("onmessage", listener);
</script>
</body>
</html>
Непосредственно ошибка:
post.html:101 Uncaught DOMException: Failed to execute 'postMessage' on 'Window': Invalid target origin 'null' in a call to 'postMessage'.
at listener (https://hst-api.mos-glonass.com/wialon/post.html:101:16)
