Retrieve all the units positions and timestamps
(24/09/2019 21:08:17 отредактировано adriangandelman)
Тема: Retrieve all the units positions and timestamps
How can I retrieve all the units positions and timestamps using Wialon Hosting API? I do have a working username and password already.
This is the kind of format that I'm looking for. Link to documentation
Is there some kind of "get all"? Otherwise just getting by any filter would be enough
Re: Retrieve all the units positions and timestamps
You can do core/search_items with following params:
    spec: {
        itemsType: 'avl_unit',
        propName: '',
        propValueMask: '',
        sortType: '',
        propType: '',
        or_logic: false,
    force: 1,
    flags: 0x1 | 0x400,
    to: 0,
rual пишет:
    spec: {
        propName: '',
        propValueMask: '',
        sortType: '',
        propType: '',
        or_logic: false,
    force: 1,
    flags: 0x1 | 0x400,
    to: 0,
I'm getting the following error:
    "error": 4,
    "reason": "WRONG_PARAMS"
This is the URL just in case. I've hid the 'sid'.
http://hst-api.mos-glonass.com/wialon/ajax.html?svc=core/search_items&sid=mysid&params={
    spec: {
        propName: '',
        propValueMask: '',
        sortType: '',
        propType: '',
        or_logic: false,
    force: 1,
    flags: 0x1 | 0x400,
    to: 0,
adriangandelman пишет:
Sorry, I provided javascript object.
You need to union flags and convert them to decimal: 0x1 | 0x400 = 1025, then serialize it to json:
{"spec":{"itemsType":"avl_unit","propName":"","propValueMask":"","sortType":"","propType":"","or_logic":false},"force":1,"flags":1025,"from":0,"to":0}
And encode uri component:
%7B%22spec%22%3A%7B%22itemsType%22%3A%22avl_unit%22%2C%22propName%22%3A%22%22%2C%22propValueMask%22%3A%22%22%2C%22sortType%22%3A%22%22%2C%22propType%22%3A%22%22%2C%22or_logic%22%3Afalse%7D%2C%22force%22%3A1%2C%22flags%22%3A1025%2C%22from%22%3A0%2C%22to%22%3A0%7D
So, correct url is:
http://hst-api.mos-glonass.com/wialon/ajax.html?svc=core/search_items&sid=mysid&params=%7B%22spec%22%3A%7B%22itemsType%22%3A%22avl_unit%22%2C%22propName%22%3A%22%22%2C%22propValueMask%22%3A%22%22%2C%22sortType%22%3A%22%22%2C%22propType%22%3A%22%22%2C%22or_logic%22%3Afalse%7D%2C%22force%22%3A1%2C%22flags%22%3A1025%2C%22from%22%3A0%2C%22to%22%3A0%7D
rual пишет:
So, correct url is:
Thank you! that worked.
(22/09/2020 12:56:08 отредактировано trushal.shah)
1)With the above APi how I cant get
The engine is ON or OFF
Car in the parking or running
Speed of the unit
Last update
Last physical address of the unit
name of the driver
svc=core/search_items&params={"spec":{"itemsType":"avl_unit","propName":"","propValueMask":"58415","sortType":"","propType":"creatortree"},"force":1,
"flags":4611686018427387903,"from":0,"to":1000}}],"flags":0}&sid=4d2ab565a7d0a1ee5fcdebe7c7bb1a63
2) How to apply filter by date to get units with all the above fields
  • Retrieve all the units positions and timestamps
