Any way to get sensor names in event updates similar to item search?
Тема: Any way to get sensor names in event updates similar to item search?
Hello, is there any parameter under event updates that can be used to display the sensor names? I noticed I am able to pull this info when running search_items but not check_updates. Would appreciate any clarification on this.
(04/05/2023 13:26:11 отредактировано zant)
Re: Any way to get sensor names in event updates similar to item search?
Omar Salem hello, events allows to get sensors values with ID and not names. So you can try to store the sensors IDs and corresponding names in your app to compare.
Here you can find the response examples -- https://sdk.mos-glonass.com/wiki/en/sidebar/ … s#response
Anton Zinovyev
Technical Care Engineer (L2)
