Teltonika FM4100
Тема: Teltonika FM4100
Hello!
I have installed FM4100 device on MAN TGA truck.
I have connected to can line and configured data to get:
Fuel consumption can1 (in wialon as Датчик абсолютного расхода топлива)
dash display can2 (in wialon as Датчик уровня топлива)
engine speed can3 (in wialon as Датчик оборотов двигателя)
engine hours  can4 (in wialon as Датчик моточасов)
vehicle distande can5 (in wialon as Датчик пробега)
My truck is on duty but I can't see data, just zeros.
Teltonika FM4100
Re: Teltonika FM4100
1) Is your FM4100 connected to KSM module of MAN, or directly to CAN bus? If to a KSM - check that KSM module is activated by truck's dealer. If connected directly to CAN bus, this data may be unavailable.
2) Check that CAN-H, CAN-L are not mixed up.
3) Check FM4100 CAN input parameters. Pay attention that output data mask order is inverted comparing to one in FMS standard description.
Аркадий Рушкевич
Teltonika FM4100
Obscured пишет:
I have connected device as shown in here: http://www.monitor-gps.ru/wares/squarel … tDiode.pdf (only i use fm4100)
2) Wires are connected correctly.
3) I am informed about inverted order.
sorry, but what is KSM module?
Teltonika FM4100
Sorry, than I don't know how to answer your question. sad
KSM module is a FMS interface, provided by truck's manufacturer. In document you mentioned Squarell plays it's role, and the document is about a vehicle without such module.
I'm not sure, that MAN without KSM has j1939 protocol in CAN bus, but most likely it has.
Аркадий Рушкевич
Teltonika FM4100
Hi,
I want to configure the Teltonika FM 4100 over air through sms commands .
Is that possible to configure the device via sms service?
Could anyone tell me the list of commands to configure the Teltonika device via sms ?
Puneet
Teltonika FM4100
Yes its possible.
Find appropriate documentation here (quick start guide): http://teltonika.lt/en/pages/view/?id=366#Fleet managment systems
Teltonika FM4100
Dear all,
Kindly suggest me if there is any method to configure Teltonika FM 4100 remotely via SMS.
I tried but no reply, so i think there may be SMS userid & SMS password issue.
If i dont know the SMS userid & SMS password, then how can i configure it to my server?
Regards,
puneet
Teltonika FM4100
(21/05/2012 23:43:14 отредактировано GoGPS)
puneetrks
Tell me pls how You create sended SMS without user and pass...
Instead of user You must insert space, instead of password You also must insert space!
Eduard Vald / GoGPS Service
www.gogps.eu
eduard.vald@gogps.eu
Teltonika FM4100
Thanks for suggesting me the solution.
Actually i don't know the user & pwd.
So, if i do as you suggested, the existing password(if any) will be replaced?
And i m in the list of Authorized nos. which can send SMS to unit.
how to go ahead?
Regards,
Puneet
Added after    1 minuts  59 seconds:
sorry i m not in the list of authorized nos...
Teltonika FM4100
there is no way to go araound this if you are not authorize or dont now the pass, that is why they do it so nobody can touch your device
Teltonika FM4100
Teltonika FM4100 allows configuring via cable without password. If you don't know password, and/or permited phone numbers are set up - the only way is to connect the device to a PC.
Аркадий Рушкевич
Teltonika FM4100
Thanks for answering. After connecting unit to PC, can i reset the password & all the settings?
Teltonika FM4100
puneetrks пишет:
Yes, freely
www.gogps.eu
Teltonika FM4100
hope your device is not have security keyword :-)
because my device have sms user / password and security keyword :-)
and pin lock for sim card too   hahaha   LOL ..
I use FM1100
Teltonika FM4100
puneetrks
Hi, you should check your mobilephone company cause I already knew the user and pass but the sim card of the device doesn't answer msm just receive. I just call to phone company and ask them to open the sim card and gave them the phone number.
Regards.
Teltonika FM4100
For the SIM card if it is locked because of incorrect password sending you have to use the PUK code to enable it.
For the reflashing of the Teltonika units it will reset everything
regards
John
Phoenix Solusi
Mobile Visible Secure
Specialists in data acquisition and analysis for mobile and fixed assets. Integration in to content management systems is a specialty we have.
Teltonika FM4100
Configuring Teltonika FM4100, FM4200 devices via TCP/IP is now available in Wialon.
The process of configuring via TCP includes the following stages:
1) the server (Wialon) sends a binary SMS to the device.
2) the device connects to the server (Wialon) to receive configuration.
3) the server (Wialon) sends configuration to the device.
4) the device breaks the connection.
User must create SMS command Upload configuration (upload_cfg) in Wialon and upload a configuration file while creating or sending the command.
Configuration file must have a certain format described in the Instruction on configuring via TCP the link to which is placed on FM4100 page on www.gurtam.com:
http://gurtam.com/en/gps_tracking/gps_h … html?id=37
The Instruction:
http://extapi.mos-glonass.com/hw/cfg/teltoni … tcp_en.pdf
Teltonika FM4100
Hi KVDM,
is this only available for the above models or for all Teltonika devices?
Thanks
Wolf.
Teltonika FM4100
wwbusch aka Buwo пишет:
Hi KVDM,
Thanks
Wolf.
Hello Wolf.
We have just tested this process for FM5300. So we will add this feature for FM5300 in the nearest time.
We are going to test FM1100 in the nearest time too.
I will make posts in the appropriate topics when this feature is available for other models.
Teltonika FM4100
Hello
Cant connect teltonika fm4100 to the PC. İts says
Please Help!
  • Teltonika FM4100
Teltonika FM4100
EminEK Which exactly data cable do you use?
Please see attach
If you have COM port on your device you should use LAN-COM cable.
If you don't have COM port you also should have USB-to-COM adapter  (don't forget to install the driver for this item and check the number of com port)
  • Teltonika FM4100
Teltonika FM4100
yavi пишет:
Please see attach
Thanks for answer yavi.
Im using both of them. (USB-to-COM and original Teltonika cable for configuration)
Whats interesting there is no problem to connect another Fm4100 devices to my notebook which also means that drivers are ok.
Teltonika FM4100
Try to check the number of COM port (In Windows device manager, tool which is responsible for USB-to-COM adapter). May be the number of com port is changed?
Teltonika FM4100
yavi пишет:
Here is the settings of port
  • Teltonika FM4100
Teltonika FM4100
It seems that smth is wrong with exactly this device...
